It is currently Mon Feb 18, 2019 5:31 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
PostPosted: Mon Feb 20, 2006 7:29 pm
I cant see the chips on it since they are covered with white plastic, but its a knock off DKU-5 cable (it worked with my nokia 3205i) and there are the following wires
No shield
Yellow
Black
Green
Red
White
Heres my pic of it apart:
There appears to be two wires on one row and three on the other like this
W R
Y B G
White Red
Yellow Black Green
Heres the cut off end:
 Post subject: tis the new dku-5
PostPosted: Wed Feb 22, 2006 1:09 pm
White and the ground shield go together to PIN 1 (GND)
Red goes to RX PIN 2 (RX)
blue goes to TX PIN 4 (TX)
yellow and green are not used.
Tried it, works for my EGay cable.
Hope this helps.
 Post subject: Re: tis the new dku-5
PostPosted: Wed Mar 08, 2006 5:39 pm
Hope this helps.
hello
I have the same cable with 4 cables ( green, white, black, red ) and ground shield .
THC07 says have the same colors of cables off me but he has a yellox cable and not ground shiel then me i have a ground shield and not yellow cable ??
I do what you say ?
thanks
PostPosted: Wed May 31, 2006 4:31 am
I got the same cable.
Did it work with those collor?
PostPosted: Mon Jun 05, 2006 1:42 pm
well red and blue are the rx and tx pins, does it matter which one goes on which pin? red for rx and blue for tx or vice versa? The thing with that cable though, it doesn't have the pl-2303 chip on it...the pl2303 chip has more pins than the chip on this cable. and it doesn't even say anything on the chip. the plastic molding says kq-u8a or whatever, but that's all. i can't get uber to recognize the ecu. it always says port not available. I've set it to the correct port and all but it doesn't work.
sorry to thread jack haha
PostPosted: Mon Jun 12, 2006 11:15 pm
Does J12 need to be cut? and also i've read somewhere that you need to burn somthing on your chip for it to work properly, does anyone know anything about this?
PostPosted: Sun Jul 30, 2006 1:44 am
j12 doesnt' need to be cut, i've gotten datalogging working with and without j12 cut. and that's on quite a few ecus now. p28, p06, p75, dunno about the rest. read my post on gettin a datalog cable to work...
PostPosted: Wed Aug 16, 2006 8:39 am
I got it working with BRE and did not cut J12
Users browsing this forum: No registered users and 8 guests
