It is currently Sun May 26, 2019 5:24 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
PostPosted: Thu Mar 23, 2006 10:46 am
Hello.
I've bought two kinds of Nokia cable ,first is cable based on chip:
1.
oti 6858
They've sad me that this is to 3200 and 5100 not for 6100 series.
Datasheet:
http://www.oti.com.tw/eng/supports/down ... _verR2.pdf
pictures:
http://156.17.231.249/pgmfi/HPIM1710.JPG
http://156.17.231.249/pgmfi/HPIM1708.JPG
I use pin configurations (TX RX),like there is on datasheet ,but something is wrong.And i realy don't know what.
I think that i used any kind of conections, so maybe I can't use this cable to datalogin.
2.
second cable I've bought was ,cable based on
Ark Micro chip 3116S ,but I can't find any datasheet in english
pictures:
http://156.17.231.249/pgmfi/HPIM1706.JPG
http://156.17.231.249/pgmfi/HPIM1707.JPG
This is for sure DKU-5 cable
I tried to use couple configurations but without any knowledge about this Ark and cable colours configuration
I tried use black as GND,second time white ,but without any results.
And there is no "wrap GND" round the all cables.
I've found drivers for each chips ,but still I have no response from Ecu Control, in some configurations it seems
that I'm conected but I have no data on ecu gauges, I use bin with datalogin.
If someone could give some advice I would be glad.
Is there any hope to run this stuff?
PostPosted: Sun Apr 02, 2006 11:36 pm
First OTI 6858 is a USB->RS232 Converter not a TTL->USB or TTL->RS-232 like what you need to use. In order to use the OTI 6858 you must use it in series with a TTL->RS232 cable.
ie. 1.ECU (TTL) --- 2.TTL->RS232 --- 3.RS232->USB
PostPosted: Wed Apr 19, 2006 3:01 pm
so am I right if I make a simple max232 on chip conwerter, it should be running?
thanks I'll try this oportunity at this weekend.
Users browsing this forum: No registered users and 8 guests
