It is currently Fri Feb 15, 2019 8:52 pm
 Post subject: ROM BURNER
PostPosted: Thu Mar 29, 2007 12:56 am
Ok I am looking for the burner for crome. Can some one please help me. I am seeing some of these but they are way diff then the one i use to tune Mitsubishi.
PostPosted: Fri Mar 30, 2007 12:48 am
You are just talking about a chip burner right? If so you have several options (Moates burn1, willems, tops, ect.) that can be used. If you already have a chip programmer it should work as well.
PostPosted: Fri Mar 30, 2007 2:04 am
Well have crome, which one would you recommend??
 Post subject: Insturctions
PostPosted: Sat Mar 31, 2007 4:37 am
http://www.moates.net
Checkout chip programmers
Purchase Burn1 and 4 extra ROMS
PostPosted: Sun Apr 01, 2007 2:26 am
you have to remove the chip each time you retune it though right?
PostPosted: Sun Apr 01, 2007 5:18 pm
Yes, if you are not using the Ostrich.
PostPosted: Sun Apr 01, 2007 6:20 pm
i would get the burn1..pretty user friendly. think about gettin the ostrich too because it makes tuning so much easier
PostPosted: Mon Apr 02, 2007 12:30 am
You can plug up the ostrich while you are tuning it so you do not have to keep taking the chip in and out right? it will just run off of that?
PostPosted: Mon Apr 02, 2007 7:41 pm
Yes, that's exactly how it will work
PostPosted: Thu Sep 13, 2007 1:14 pm
do u have to modify the car ECU (add a chip) to tune or change rom settings using ostrich
PostPosted: Thu Sep 13, 2007 6:33 pm
You have to add a socket for the chips/emulator to connect to if that's what your asking.
Users browsing this forum: No registered users and 31 guests
