It is currently Sun Jan 20, 2019 12:22 am
 Post subject: obd0 b16 92 integra
PostPosted: Mon Apr 13, 2015 8:56 am
Hello I recently swapped in a obd0 b16a into my 1992 acura integra. I currently have the engine running on a chipped P28 with a modified p61/p72 base map. I'm having issues finding a P30 map that will run my engine without issues. Every P30 base map I have tried on my b16a either doesn't start or runs super super super rough. So the only bin files/maps that only work are p72 base. I have tried copying low cam ign and fuel maps from every P30 bin I can find but not a single P30 works. Not having any better luck with 0bd1 pr3 files. However the p61 low cam maps seem to run the engine just fine when they are copied to a p74 and then applied p72 b18c high cam maps. Although power feels a bit to weak in between 5000-7000 rpm's. Has anyone else had similar issues with this or can any one offer any advice?
Here's a little about the engine and car
1992 acura integra ls
Jdm obd0 b16a,72mm throttle body,skunk 2 intake manifold, aem cold air intake, oem b18a header, oem obd1 injectors and chipped/ converted auto P28 ecu. Currently running p61 low cam and p72 b18c high cam.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 16 guests
