It is currently Tue Jan 22, 2019 4:09 am
PostPosted: Mon Feb 26, 2018 2:36 pm
Hello there,
I decided to join the forum because of problems with my ECU. The experienced mechanic swapped the H22A JDM to my european OBD1 which used to run with F20A4 engine. We had problems with idle and find out that P13-J50 got issue with opnening butterflies, we switched the ecu with the 100% working piece and the problem gone.. So, I'm looking for new one and in the same time for solution to fix my P13(which i got in my closet).. Why? Because already 4 ecu's checked by users had same issue.. I also checked them by myself and always the 100% working move the IAB and the rest not. The problem is, I could not find any instruction or solution and thats why I'm here. Would be so purrrfect if You could help me to fix my ecu. Ofcourse I know how to solder and desolder, I could try to measure something if need it by multimeter. Help me :).
Users browsing this forum: No registered users and 28 guests
