It is currently Fri Feb 15, 2019 8:38 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Thu Aug 04, 2005 3:53 am
I leared how to datalog from this write up, Thanks. Now i am trying to use the auto adjust feature with no sucsess, and i have not found any info on the subject.
 Post subject: Re: can't connect
PostPosted: Tue Aug 09, 2005 9:27 pm
Rdeceptions wrote:
I am using a Moates Hulog and burner, P28 ecu all set up. Trying to get datalogging working, i will be getting the innovate wide band in a few weeks. i went through the whole process above step by step and all i get is Bad Response. Checksum is removed, datalog added. according to device manager the hulog is working fine, but i cant connect, any ideas? the map is a base P30, running a LS/VTEC with Type-R internals.
i have the same datalogging kit and ecu and the same problems can someone help.this is driving me crazy
PostPosted: Mon Mar 06, 2006 1:13 pm
did this ever make it into the wiki?
it may be beneficial for the new users if you explain whether you're using crome pro or freelog, etc, for datalogging.....
PostPosted: Wed Jul 19, 2006 10:47 pm
this should be a sticky!!! :lol:
PostPosted: Sun Jun 15, 2008 11:36 pm
is this for Crome Pro?
PostPosted: Fri Oct 30, 2009 2:14 am
i have j12 in my ecu what does it do and why should i remove it? also should i desolder it or just cut it?
